Laminar-turbulent slope change in heat transfer |
May 7, 2012, 12:56 |
Rep Power: 15 |
Hello everyone, I hope you guys can give me a hand about the next question:
I have calculated the heat transfer rate to the walls from hot fluid along a pipe typical of a heat exchanger (the walls have some turbulence promoters). The CFD code I am using is Ansys CFX. I did this for several Reynolds numbers in the laminar range (Re=100-3000), I used no turbulence model here. Then I went into the turbulent range (Re=2000-30000) using the SST model. Finally I plotted an averaged Nusselt number over the walls surface vs inlet Reynolds number. Contrarily to what I was expecting, I did not observe a change in slope in the Nusselt number for the two ranges considered. I was expecting to get a steeper slope in the turbulent region, as turbulence is supposed to enhance heat transfer. Do you guys have any idea as to why I am not getting this slope change? Just to clarify, I am not trying to predict laminar-turbulent transition, since I guess this is far beyond this code capabilities. Alright, thanks a lot for your help. Cheers. |
Display Modes | |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
Turbulent heat transfer calculation | Frank Rubensdorffer | FLUENT | 2 | May 29, 2002 14:37 |
Heat transfer coefficent in turbulent flow | Ola Lindgren | Main CFD Forum | 2 | November 17, 1998 05:49 |
