Laminar-turbulent slope change in heat transfer
Old   May 7, 2012, 12:56
Default Laminar-turbulent slope change in heat transfer
michujo is on a distinguished road
Hello everyone, I hope you guys can give me a hand about the next question:
I have calculated the heat transfer rate to the walls from hot fluid along a pipe typical of a heat exchanger (the walls have some turbulence promoters). The CFD code I am using is Ansys CFX.
I did this for several Reynolds numbers in the laminar range (Re=100-3000), I used no turbulence model here. Then I went into the turbulent range (Re=2000-30000) using the SST model.
Finally I plotted an averaged Nusselt number over the walls surface vs inlet Reynolds number. Contrarily to what I was expecting, I did not observe a change in slope in the Nusselt number for the two ranges considered. I was expecting to get a steeper slope in the turbulent region, as turbulence is supposed to enhance heat transfer.
Do you guys have any idea as to why I am not getting this slope change? Just to clarify, I am not trying to predict laminar-turbulent transition, since I guess this is far beyond this code capabilities.
Alright, thanks a lot for your help.
Cheers.
michujo is offline   Reply With Quote
Thread Tools
Trackbacks are On
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Turbulent heat transfer calculation Frank Rubensdorffer FLUENT 2 May 29, 2002 14:37
Heat transfer coefficent in turbulent flow Ola Lindgren Main CFD Forum 2 November 17, 1998 06:49
