Experimental data for 2D conjugate heat transfer
I am a M.D processing student at college. Recently, I would like to study 2D conjugate heat transfer , but I can not find experimental data for validate my code. So, if you have any information or already have it, please tell me. Thank you for reading my message. God bless you!
Re: Experimental data for 2D conjugate heat transfer
There are some test data for turbine vane cooling. You may read
Hylton, L.D. et al. "Analytical and experimental evaluation of heat transfer distribution over surface of turbine vanes", NASA CR 168015, 1983. It is a very thick report. Be caution! there are some errors in the test conditions! God bless you, too. |
(1). You may want to contact CFD software vendors because some of the software can handle conjugate heat transfer problems . (2). I think they should have some experimental data to validate their results and codes.
The following article will prove useful in validating your code:
Kim, D.M. & Viskanta, R. 1984 Study of the effects of wall conduction in differently oriented square cavities. Journal of Fluid Mechanics, Volume 144, pp 153-176. Good Luck. - abhijit |
