immersed boundary method of Markus Uhlmann
Like Tree1Likes
  • 1 Post By arjun
Old   May 7, 2012, 03:51
Post immersed boundary method of Markus Uhlmann
dishengbin
dishengbin is on a distinguished road
Hello, everyone.
I’ve tried the immersed boundary method proposed by Ulhmann (Uhlmann, M. (2005). "An immersed boundary method with direct forcing for the simulation of particulate flows.”). I have doubt about the determination of Lagrangian markers (requires ds=dx)the mathematical expressions are in the attachment. Can anybody explain the reason? Thank you very much!
dishengbin is offline   Reply With Quote
Old   May 8, 2012, 20:34
dishengbin
anybody kowns the reason? thank you in advance
Old   May 8, 2012, 23:06
Arjun
arjun will become famous soon enougharjun will become famous soon enough
i can't open .docx so i can't comment.
arjun is offline   Reply With Quote
Old   May 8, 2012, 23:45
dishengbin
hi Arjun, thanks for your reply. I do not know how to add mathematical equations in the message. My doubt is why the distance of the markers is required to be equal to the cell length? thank you .
Old   May 9, 2012, 04:05
Arjun
I have experience with writing immersed boundary codes so i thought I might be able to help.
But I haven't read the original paper you quote and I do not have access to it. I thought your docx might give me some hints to what you are talking about but I can not open that either.
Anyway, if I have to just guess blindly, my guess is that he require ds=dx etc because of ease of interpolation (creating a interpolation function) or ease of marking solid and fluid points. Solid marking is tough and time consuming task if grid is not uniform or if grid is unstructured.
dishengbin likes this.
Old   May 9, 2012, 05:44
dishengbin
Thanks for your explanation. Yes, you are right, he requires ds =dx, http://www.sciencedirect.com/science...21999105001385
(i'm not sure whether you can access it)
In equation (9b), dv = dx*dy = ds*dx(dy). in 2D case. But in the flow past a stationary circular cylinder, when I use more or less markers, the drag/lift force varies significantly. In some other papers , dv is replaced by ds. So could you let me know the reason? thanks
immersed boundary method, lagrangian markers, uhlmann
implementation of the Immersed Boundary Method mi_cfd Main CFD Forum 19 April 24, 2019 01:24
Immersed boundary method (IBM) vs Dynamic meshing tomyangbath Main CFD Forum 5 April 17, 2009 03:02
Immersed boundary method with momentum forcing Fuka Main CFD Forum 1 February 6, 2006 03:46
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
