Theory - Flow between two cylindrical plates
Old   May 14, 2012, 09:42
Default Theory - Flow between two cylindrical plates
Bhageshvar
bageshwar is on a distinguished road
I have to theoretically calculate the flow between two cylindrical plates.
This is the spec:
Two plates of 15cm radius separated between them by a 1cm gap
flow between those plates to be studied.
And its laminar flow
*I know how the flow between rectangular parallel plates of infinite length works, but not how this works, Can anyone give any link to a theory or any suggestions to solve this?
bageshwar is offline   Reply With Quote
Old   May 22, 2012, 09:44
Eugeny
chlp is on a distinguished road
"Cylindrical plates"? So it cylinder or plate?
chlp is offline   Reply With Quote
Old   May 22, 2012, 11:12
Bhageshvar
It is two plates parallel to each other. the places are cylindrical in shape with 0.15 m radius and 1mm height each. So i have a flow of air passing between these plates. I want to know if there is a theory for such a system, or how could it be derived
Old   May 22, 2012, 13:06
Eugeny
Can you draw the pictures, eg. in mspaint?
Old   May 22, 2012, 13:13
Bhageshvar
I have attached the file with this post
Old   May 22, 2012, 13:48
Eugeny
How to draw this model? I do not understand...
Old   May 22, 2012, 14:06
Bhageshvar
try this image
Old   May 22, 2012, 14:24
Eugeny
so, no?
Old   May 22, 2012, 14:29
Bhageshvar
yes the flow is through the thin region not the cross sectional area.
The flow is betwwen the plates
Old   May 22, 2012, 14:34
Eugeny
Seems i have never seen before theoretical solution, simulation can be help?
Old   May 22, 2012, 14:35
Bhageshvar
I have the results for the simulation, but need a theory to validate it. Thats what I am currently struggling upon.
Old   May 23, 2012, 12:20
michujo is on a distinguished road
Hi Bageshwar, if I have understood correctly, your problem is basically a Poiseuille flow between two concentric cylinders, is that correct?
The solution is pretty straightforward, just take the Navier-Stokes equations in cylindrical coordinates and start killing terms!
For instance:
- Stationary flow: kill \frac{\partial}{\partial t} terms
- No variation along z coordinate (axis of the cylinders): kill \frac{\partial}{\partial z} terms, except for pressure!
- No variation along circumferential coordinate: kill \frac{\partial}{\partial \phi} terms
Considering incompressible flow you do not need the continuity nor the energy equations so you end up with something like this:
-\frac{\partial P}{\partial z} +\mu \left[ \frac{1}{r}\frac{\partial}{\partial r} \left ( r\frac{\partial u_z}{\partial r} \right )\right ]=0
, where P is pressure, r is the radius, z is the direction along the axis and u is the velocity.
Solving for u_z(r) you get:
u_z(r)=\frac{\partial P /\partial z}{\mu }\frac{r^2}{4} +A ln(r)+B
Now find the values of A and B imposing boundary conditions at the inner and outer cylinder walls, u=0 at R1 and R2 respectively:
A=-\frac{\frac{\partial P/ \partial z}{\mu } \frac{R_2^2-R_1^2}{4}}{ln \left ( \frac{R_2}{R_1 }\right ) }
and
B=-\frac{\partial P/\partial z}{\mu }\frac{R_1^2}{4} -A \cdot ln R_1
So that's the velocity profile in the radial direction. Then you will just have to substitute for the numerical data of your problem.
Is this what you were looking for? (please say yes! ).
Cheers.
michujo is offline   Reply With Quote
Old   May 23, 2012, 12:24
Default just trying to understand
  #13
Patrick Godon
PGodon is on a distinguished road
I suppose the disks are not rotating, these are just two circular (not cylindrical) plates. The flow between them will depend on the viscosity and velocity, or if you prefer on the Reynolds number. You will have two boundary layers forming, one on each plate. If the Reynolds number is small, these two boundary layers might actually join together, which would likely happen far from the circular edges, towards the center. There the flow velocity will be minimal (depending on the viscosity the velocity could even be zero in the center of the circular plates). I expect the velocity to be maximal (but still smaller than the "outside" bulk velocity) at the edges, especially the edges where the flow is tangential to the circular boundary. If the Reynolds number is large, I would expect microscopic boundary layers and the flow might be almost unaffected between the plates. On the overall I expect (guts feeling) the flow velocity to be minimal towards the center (maybe within a given a radius it could have a constant value which would decrease with decreasing Reynolds number). That's my 5 cents comments. I hope it helps.
To me it seems it might be a good way to maybe use this configuration to possibly create almost a stationary flow between the plates in the center, maybe even this could be use for a two phase flow to separate or isolate one of the two components (say particles). Am I guessing right!?
PGodon is offline   Reply With Quote
Old   May 23, 2012, 12:37
Ok, now I see that I did not understand the configuration, damn!
Could you please explain where is the inlet and where is the outlet? I do not clearly see it.
Do you inject it through a hole in the center? or the flow enters radially towards the center and goes out through a hole there?
Cheers.
Old   May 24, 2012, 02:58
Bhageshvar
Hi all, the disks are not rotating. It is a compressible flow, and I do not want a stationary solution, but i need a time dependent solution. Moreover, Its a flow between two thin cylinders let us assume. the thin cylinders are parallel to each other, the flow just passes between the gaps as I had mentioned in the previous images.
Please let me know.
Thread Tools
Trackbacks are On
Radial flow between parallel plates gfcoppola OpenFOAM Running, Solving & CFD 1 October 22, 2010 05:42
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Cylindrical laminar flow Toni CD-adapco 2 July 13, 2004 06:44
need 3D cylindrical source code for laminar flow S. D. Ding Main CFD Forum 0 July 23, 2002 02:01
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
