Forced convection and CHT : can we disable pressure and velocity solvers ? |
April 4, 2012, 09:09 |
Rep Power: 14 |
Hi everybody,
I would like to simulate a Conjugate Heat Transfer problem where the fluid properties (density and viscosity) are independent of temperature. It is a forced convection case. Suppose I already get the pressure and velocity fields through a steady state simulation in the fluid region. The question is: can I run a CHT simulation (with time varying T boundary conditions) where p and U are initialized by the steady state solution and only energy equations are solved (in the fluid and solid regions with heat transfer). I can do so by setting the target residue of the pressure and velocity equations to 1. Is this correct ? This proceedure could save a lot of CPU time Thank u for your help. M3hdi |
April 5, 2012, 09:27 |
Rep Power: 14 |
..the underlying hypothesis would be that the temperature field does not change the pressure and velocity solutions. Is this correct in a physical point of view ? (for incompressible fluid with constant density and viscosity)
May 31, 2012, 04:42 |
Rep Power: 14 |
... none ?
May 31, 2012, 08:04 |
Joern Beilke
Rep Power: 20 |
That's a usual way to deal with that problem. So try it and look if you get reasonable results.
May 31, 2012, 08:57 |
Rep Power: 14 |
Thank you for the answer !
