LU-SSOR Method
Old   November 14, 2005, 08:24
Default LU-SSOR Method
A.M.Yang
When I used Jameson's LU-SSOR method, I found the coeffient of spectral radius was ofen much greater then one,for example 1.8. Only the large value can let the scheme converge. I wonder What is the reason. Thanks!
Old   November 14, 2005, 11:05
Default Re: LU-SSOR Method
Tom
In SOR the relaxation parameter needs to be greater than 1 and as the resolution increases the optimal value tends towards 2.
