Pressure drop momentum source model
Old   June 1, 2012, 21:58
Default Pressure drop momentum source model
Chris
delic is on a distinguished road
I wrote a pressure drop momentum source model for a CFD code and I am having problems with unrealistically high density (causes low temperature via gas law) in the source volume, particularly in low velocity areas. It is almost like the density rises instead of the static pressure dropping in those areas.. (Ptot=Pstat+1/2rhoV^2). The code solves the five rho, rhou, rhov, rhow, and rhoe.
The source model is fairly simple. Force=Pressure*Area=A*V^B*AreaOfCell where A and B are the constants to a power fit and V is the velocity component. A pressure drop is computed for the x,y, and z directions.
I tried linearization of the source terms, damping, relaxation, etc with no luck. I tried running laminar and invisicid with same results. I feel like I am missing some major piece of the physics or numerics or something.
If anyone has any ideas/hints I would love to hear them, especially if you have written a pressure drop/fan source model in a CFD code.
Chris
delic is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Element coordinates for momentum source model CFDworker CFX 3 October 10, 2007 11:05
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
