Exporting Gambit to Fluent v4
Old   July 16, 1999, 08:46
Default Exporting Gambit to Fluent v4
R.Wilkins
I am having problems exporting mesh files created in gambit to fluent v4. Geometry is orientated differently. This is only a problem when solving a problem using deforming mesh model, when subsequent grid files need to be identical. Each subsequent grid file is orientated in a different manner when viewed from within fluent.
If anyone can help I would be obliged !!!
Old   July 21, 1999, 14:50
Default Re: Exporting Gambit to Fluent v4
Phil Greenfield
I'm also working with a deforming mesh and went back to geomesh to provide the grid sequences. Also, since Gambit is the front-end for Fluent 5 (& Fidap, etc), question wether it's backward compatible. If you find a way, I'd also be interested in this information. Phil
Old   July 21, 1999, 17:05
Phil Greenfield
You got me curious ! Just tried producing, exporting and reading a Gambit file to Fluent 4 and it does work. In Gambit, pick the Fluent 4 solver option and then export - mesh which leaves as a *.grd file.
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 07:28
gambit with linux and fluent 12.1 kharnabnew FLUENT 0 October 5, 2010 10:33
exporting from Fluent back into Gambit tom FLUENT 0 June 23, 2008 17:55
Exporting Meshes from ICEM to Fluent zi FLUENT 4 August 9, 2005 11:58
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 13:35
