CFB solids flow rate
Old   June 6, 2012, 09:31
Smile CFB solids flow rate
meng
694005136 is on a distinguished road
Now I'm trying simulating a CFB riser using E-L model. I want to compare its results with experimental dates in literatures. At the inlet, gas velocity and solids flow rate should be given, and at the outlet, pressure(atmosphere) is set. A no-slip condition is used for gas phase at the walls. Usually gas velocity and solids flux (unit is kg/m2s) are given in literatures, but I must get solids flow rate (unit is kg/s) for inlet BC. The question is how can I convert solids flux to solids flow rate. I know it's not simply product of the solids flux and riser cross-section area.
I hope someone can help me, thanks in advance.
694005136 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
