ALGOR? Its scripting language? Compare to Fluent?
Can anybody comment about ALGOR?
Does anybody know what its scripting language is like? Can you compare it to Fluent (the package I know best), or FloWorks/SolidWorks, or FlexPDE? My application is CFD and heat transfer with industrial forced air convection heating, primarily automated parametric studies. Am considering trying ALGOR. Primary motivation is the difficult scripting language Fluent uses. Thanks! -Chris |
Re: ALGOR? Its scripting language? Compare to Flue
Algor does not solve the conservation, momentum & energy equations simultaneously - as required for a full solution of the N-S equations. It is not able to solve momentum + energy eqn for fluids - only momentum.
IMHO, Algor will give you some pretty pictures - but that is about all. It is also excrutiatingly slow. I have many years experience with their offerings, but more recently I only concentrate on the solid-stress applications. For the rest, Algor is simply not up to scratch. Their marketing hard-sell policies also leave a lot to be desired. IMHO, avoid them if you can. Fluent would be the way to go for true multi-physics. diaw... |
Try CFD-CADalyzer http://www.esi-group.com/SimulationS...CFD_CADalyzer/
I hear it is integrated with CAD packages, so it can recognize parameters created in CAD and uses them to run parametric studies. |
