Cf over flat plate obtained by SST k-omega
Old   June 8, 2012, 20:16
Default Cf over flat plate obtained by SST k-omega
Mehdi Baba Mehdi
mb.pejvak is on a distinguished road
Hi everyone
I applied SST k-omega turbulence model on the code, I could simulate steady, incompressible turbulent flow past over Two-dimensional zero-pressure-gradient flat plate. first of all I should mention some details about grid. computations were performed on a grids of size 273×193. dimension of domains are −0.33333 < x < 2 and 0 < y < 1. grid spacing (wall normal direction) was 1 × 10−6.
according to my results for Re=2e6 and comparison with theoretical formula used for Cf (Skin Friction coefficient, Cf= 0.025Re exp(-1/7)), you can see in attached file result is not very good. but in U+-Log Y+ results is good I think based on numerical result that other obtained (
Rumsey and Spalart) specially in sublayer.
So my question is why in sublayer U+ profile is completely match with theoretical profile but cf is not? and do you think what problem exist?
mb.pejvak is offline   Reply With Quote
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 21:09
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 07:56
flat plate transition: SST k-omega divergence Peter Gasparovic FLUENT 4 May 3, 2005 13:54
