June 16, 2012, 03:09 |
Two Questions for Turbulence Modeling
Mohammad Sarfaraz
Rep Power: 16 |
Hi all
I have 2 questions, which I would be thankful for recieving their answers: 1- When using k-epsilon model, what is the B.C. for the values of k and epsilon? 2- When adopting log. wall law, how does it work? give an example. Regards, |
June 17, 2012, 00:43 |
Mehdi Baba Mehdi
Rep Power: 15 |
I recommend you to read "An Introduction to Computational Fluid Dynamics" by Versteeg. it is good for start. and " Turbulence modeling for CFD" by Wilcox D.C. is very good in explanation of wall function.
June 18, 2012, 06:35 |
Chris
Rep Power: 14 |
Also good book "Computational Methods for Fluid Dynamics" by Ferziger is good.
the k-epsilon model cant model the near wall region and thus a wall function is needed to solve the sub viscour near wall region. For this your meshing needs to be adequate so that y+ is between 30 and 300. This is what it is describing when mentioned log law. Also your BC for the flow and values for k and epsilon will be dependant on the flow. See software help for equations which may be used to get these values. |
Questions about smoke modeling using CFX | rafiktharwat | CFX | 0 | March 14, 2011 11:38 |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 15:55 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
more multiphase modeling questions | Shane Gillis | FLUENT | 0 | September 4, 2000 19:45 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
