Wall Velocity is maximum!!!!!!!!
I have modeled a simple cylinder as a fluid ( Water mesh) in CFX. With the following boundary conditions: Inlet: Normal velocity Wall: no slip Outlet: 0 Pressure But strangely in post processing, when I measured velocity in the wall, it was not zero and in many sections, it was even more than average velocity in the section. It is strange because I have defined walls to be no slip. Could you please advise me to know the reason for this result? |
| All times are GMT -4. The time now is 07:01. |
