Low Reynolds Airfoil Modeling In Fluent
Old   October 23, 2011, 09:49
Default Low Reynolds Airfoil Modeling In Fluent
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
Hi. I am modeling anderson Spica airfoil in fluent.
the maximum velocity is 40m/s.
the Grid is CH
what is the best boundary condition for inlet outlet and upper and lower boundary.
which solver can predict the cl and cd more accurate.
what about under-relaxation factors? discretization methods and pressure velocity coupling?
I did not get good result by my own settings.
the residuals remain in high value. and cl and cd oscillate.
morteza08 is offline   Reply With Quote
Old   October 24, 2011, 06:03
FlowLy
giuli@ is on a distinguished road
I would put Pressure Far Field for all the boundaries.
kw-SST usually is the most accurate; but for airfoil you can use Spalart-Allmaras, is computationally cheaper than kw-SST and was developed especially for this application.
Under-relax factors: keep the default; if you have problem with convergence it can help if you lower them. But usually, if it does not converge, there must be a problem either in the formulation of the problem (BC) or in the mesh, or in the geometry..
Hope this help
cheers
giuli@ is offline   Reply With Quote
Old   October 31, 2011, 12:46
morteza08's Avatar
Morteza
Thank you so much dear Guili
Old   November 23, 2011, 04:40
aerospaceman is on a distinguished road
You have to watch out for transition, as none of the RANS models accurately captures it. Therefore your Cd maybe higher than results obtained in the literature. XFOIL should also help.
aerospaceman is offline   Reply With Quote
Low Reynolds Modeling Lam Bremhorst Mo-ITB OpenFOAM Running, Solving & CFD 3 November 17, 2017 11:07
Low Reynolds Modeling Mo-ITB OpenFOAM Running, Solving & CFD 0 June 16, 2010 03:10
Flapping Airfoil Simulation in Low Reynolds Number Flow M.Sc_Student Main CFD Forum 0 April 6, 2010 09:30
Fluent 12.0, Low Reynolds Number Flows anandvksin2003 FLUENT 1 January 26, 2010 05:16
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
