airfoil data
Old   July 16, 1999, 08:53
Default airfoil data
Tim
Hi there,
does anyone know a website where I can find good data (lift, drag, c_p ..) of a NACA airfoil for validating a cfd-code. A 3D case would be the best.
Thanks,
Tim
Old   July 16, 1999, 21:52
Default Re: airfoil data
John C. Chien
(1). I would suggest that you start with simple test cases first. (2). Check out the code first for laminar flows. Then move on to the simple turbulent flows. (3). If you can pass these two tests, then try the airfoil cases.
Lift and Drag Coefficient data for NACA 2412 Airfoil mahbub03 Main CFD Forum 22 May 25, 2014 15:39
Help, find 2d multi-element airfoil geometry data liujmljm Main CFD Forum 0 June 5, 2009 09:24
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
About low Reynolds number airfoil experiment data. zqnwpu Main CFD Forum 5 December 25, 2004 03:52
Where can find airfoil data with pressure distribution or aerodynamic data Ahlo Main CFD Forum 5 January 12, 1999 22:45
