multi-dimensional dynamic array allocation for multi-block solver using fortran
Old   June 24, 2012, 04:48
Post multi-dimensional dynamic array allocation for multi-block solver using fortran
Manokaran K
mano is on a distinguished road
I am converting my CFD solver to multi-block solver. I had used dynamic array allocation for the single block solver, but for multi-block, the dynamic array allocation syntax is not clear to me. I tried a sample code, but end up in error "Error: Expression at (1) must be scalar". I also don't know how to pass the multi dimensional allocated array to subroutines. Please, suggest solution, regards
common/iteration/nb
integer, dimension (,allocatable::nib,njb,nkb
real, dimension (:,:,:,,allocatable::x,y,z
allocate (nib(nb),njb(nb),nkb(nb))
do l=1,nb
ni=nib(l)
nj=njb(l)
nk=nkb(l)
allocate (x(l,ni,nj,nk),y(l,ni,nj,nk),z(l,ni,nj,nk))
enddo
call gridatt (x,y,z,nib,njb,nkb)
deallocate(x,y,z,nib,njb,nkb)
end
c
subroutine gridatt (x,y,z,nib,njb,nkb)
common/iteration/nb
integer, dimension (nb)::nib,njb,nkb
real, dimension (nb,nib,njb,nkb)::x,y,z
return
end
mano
mano is offline   Reply With Quote
Old   June 24, 2012, 15:03
Mohammad Reza Hadian
hadian is on a distinguished road
you can not declare an array with variable values for different indexes. thry should be fixed values. i know in this way you waist some amount of memory but there is no way ( as i know). your code should be like this:
common/iteration/nb
integer, dimension ( : ),allocatable::nib,njb,nkb
real, dimension (:,:,:,: ),allocatable::x,y,z
c calculate maximum value of ni, nj and nk in all blocks and store them in MaxNi,MaxNj and MaxNk respectively
allocate(x(nb,MaxNi,MaxNj,MaxNk),y(nb,MaxNi,MaxNj, MaxNk),z(nb,MaxNi,MaxNj,MaxNk))
call gridatt (x,y,z,MaxNi,MaxNj,MaxNk)
end
c
subroutine gridatt (x,y,z,MaxNi,MaxNj,MaxNk)
common/iteration/nb
integer, dimension (nb)::MaxNi,MaxNj,MaxNk
real, dimension (nb,MaxNi,MaxNj,MaxNk)::x,y,z
return
end
hadian is offline   Reply With Quote
Old   June 25, 2012, 10:24
Manokaran K
Thank you for your comments.
Well, your suggestion is to use maximum value in i,j,k direction from all blocks. It will work, but sometimes, if the block size varies drastically, this may not be optimum and giving the boundary conditions will be a tough job.
mano
Old   June 25, 2012, 10:50
yes, you are right. but as i know there is no other way. if you want to use the memory efficiently, you should use one array and put the values of different blocks in continuous series. then you can access to any every variables of every block by knowing the size of its previous blocks. i think the following paper can help you in this way. note that the programming of this method is not easy.
Lien, F.S., Chen, W.L. and Leschziner,M.A. (1996). “A Multiblock Implementation of Non-Orthogonal Collocated Finite Volume Algorithm for Complex Turbulent Flows”, Int. J. Numer. Methods Fluids, 23, 567-588.
Old   June 25, 2012, 21:01
Manokaran K
Thank you very much. Regards
mano
dynamic array, fortran, mult-block
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
