-   -   how to specify the inlet turbulence kinetic energy (http://www.cfd-online.com/Forums/main/10394-how-specify-inlet-turbulence-kinetic-energy.html)
rajesh December 3, 2005 05:26
Can any body please help me how to specify inlet boundary condition for turbulent flow. Because it is asking for parameters like turblence reference velocity, % mean velocity, % hydraulic diameter, turbulence kinetic energy, turbulence dissipation rate.
Rashmi December 3, 2005 07:00
Re: how to specify the inlet turbulence kinetic en
hi can u tell me what u r modeling so that i can answer ur question
Rashmi
rajesh December 3, 2005 07:16
i am trying to model water cooling jacket of a diesel engine, for that i need inlet specifications. i know the mean mass flow rate and pressure. thank you
Halim December 3, 2005 19:52
The followings are what the CFX code is doing;
TEin=1.5*(0.037*Vin)**2,
EDin=TEin**1.5/(0.3*D)
where TEin is the turbulent kinetic energy at inlet, EDin is its dissipation rate at inlet, Vin is the inlet velocity and D is the inlet length scale such as the hydraulic diameter. The value 0.037 (3.7%) is the turbulence intensity and you can change it. I hope this helps.
Good luck,
Halim
jainsiddhant19@gmail.com July 29, 2015 07:27
Can u please tell me the source of above info
