Jet Lagrangian Simulation
Old   July 3, 2012, 14:29
Default Jet Lagrangian Simulation
Ghassan Nasif
Gus Nasif is on a distinguished road
Hi everybody,
I am working on water Jet impingement with heat transfer, Since I have a continuous jet of water , I used a VOF to simulate the problem and I got a good results , as well as I got a sharp interface between water and air. The issue is that The VOF is an expensive approach and it requires a high resolution mesh and small time step.I am trying to simulate the same problem using Lagrangian approach, and I have few qestion, hopefully somebody can answer them:
  • The first question , is it Lagrangian approach convenient to simulate such problem (Re= 5000), because I have a continous jet and not expecting a break-up.
  • My understanding for the Lagrangian approch is that the size of the injected particles will affect the solution since the incidient weber number is function to the size of particle diameter, the question here how can I define the size of the particle (i.e. shall I use one particle at the same nozzle diameter, or many particles with a constant diameter, or many particles have a distribution size, etc.).
  • The last question, do I need to include a thin film in my model, I am expecting the particle will splash after impings the wall .
Since this my first time of using CFD online, I appreciate if you can send your answer using my e-mail address nasifg@uwindsor.ca
Thank you
Gus
Gus Nasif is offline   Reply With Quote
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
Simulation of single Axisymmetric jet 2d gcyshetti OpenFOAM Running, Solving & CFD 0 March 18, 2009 01:13
grid stretching function for jet simulation Bobby Main CFD Forum 0 May 29, 2005 13:46
air jet simulation Yue zou Main CFD Forum 0 September 28, 1998 08:30
