-   -   Parallel solver for Poisson equation using PETSc (http://www.cfd-online.com/Forums/main/104274-parallel-solver-poisson-equation-using-petsc.html)
JackNapier July 5, 2012 16:53
I am using the PETSc library to solve numerically the Poisson equation.
My domain is a square and the mesh is uniform. The poisson equation is discretized with
a 5-points stencil. The BCs are of Dirichlet's type.
To test the solver I compared an analytical solution with the numerical one and I found out my code produces incorrect results.
If I solve the system with the identity matrix, I am able to recover the know-terms vector, thus I suspect I am not setting up properly the off-diagonal elements of the coefficient matrix.
Is there anyone with some experience in using PETSc who could help me?
Regards,
Michele
