Parallel solver for Poisson equation using PETSc
Old   July 5, 2012, 16:53
Default Parallel solver for Poisson equation using PETSc
Michele Rosso
JackNapier is on a distinguished road
Send a message via MSN to JackNapier
I am using the PETSc library to solve numerically the Poisson equation.
My domain is a square and the mesh is uniform. The poisson equation is discretized with
a 5-points stencil. The BCs are of Dirichlet's type.
To test the solver I compared an analytical solution with the numerical one and I found out my code produces incorrect results.
If I solve the system with the identity matrix, I am able to recover the know-terms vector, thus I suspect I am not setting up properly the off-diagonal elements of the coefficient matrix.
Is there anyone with some experience in using PETSc who could help me?
Regards,
Michele
JackNapier is offline   Reply With Quote
parallel computing, petsc, poisson equation
Two equation turbulence models solver settings truffaldino FLUENT 0 March 5, 2011 20:49
temperature equation for one phase in multiphase solver romant OpenFOAM Programming & Development 0 April 13, 2010 05:06
Solver crashes (PVM parallel) Marco Müller CFX 2 February 4, 2009 02:51
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 11, 2007 23:48
direct parallel solver sylvain Main CFD Forum 2 June 25, 2001 07:56
