July 11, 2012, 12:21 |
Filtering DNS data
SM
Rep Power: 15 |
Hello!
I see in literature people filtering DNS data to compare them with LES simulations. The filter used in most cases is Gaussian whereas if I understand correctly when LES is performed with FVM and an SGS model its more like a top hat filtering. So does that mean Gaussian or tophat filtering on DNS data will yield same result? In case if this concerns reacting flow (combustion) does anything change? Thanks in advance |
July 11, 2012, 15:00 |
Alex
Rep Power: 46 |
I can't provide you with a conclusive answer to this question.
But have a look at the book by Pope: turbulent flows The filtering operations of LES and the resulting filters are discussed in detail. |
July 11, 2012, 16:17 |
SM
Rep Power: 15 |
I know the book (I think so do all the people who work with turbulence)
and have gone through the chapter on LES. Can you point which section in particular? |
July 11, 2012, 16:47 |
Filippo Maria Denaro
Rep Power: 71 |
The matter is very complex... in principle, also filtering DNS there is no necessarily link with LES solutions ...
however, if you use FVM I suggest using a top-hat to post-filter DNS. What's more, you should use a top-hat that is as similar as possible to your implicit filter, built-in by the FV methods... Try searching in google, you will see some papers about filtering issues... |
July 12, 2012, 10:49 |
SM
Rep Power: 15 |
Thanks for your suggestion.
Any references? |
July 12, 2012, 11:04 |
Rep Power: 71 |
You can find many references on the major journals such as JFM, JCP, POF, C&F, TCFD, ecc ... also a simple google search can help: https://www.google.it/search?q=large...C6X_4QTtwuHwBg |
Display Modes | |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
Looking for DNS data: Couette flow | Hui | Main CFD Forum | 2 | April 16, 2008 13:44 |
Benchmark flows? DNS data ? | karuna | Main CFD Forum | 0 | June 3, 2006 19:05 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
How to do filtering of 3D DNS data | chinthakindi | Main CFD Forum | 0 | January 27, 2004 09:14 |
