Set up a wind velocity for an experiment.
Old   August 8, 2012, 02:20
Default Set up a wind velocity for an experiment.
bitacovir is on a distinguished road
I'm using ElmerGUI as cfd software and I want to set up the velocity of the flow (wind). I understand this instruction of a tutorial is to create a parabolic profile of the flow in velocity 1...
Model
BoundaryCondition
Name = Inlet
Navier-Stokes
Velocity 1 = Variable Coordinate 2; Real MATC "4* 1.5 * tx * (0.41-tx)/0.41^2"
Velocity 2 = 0.0
Add
New
I understand that this equation (for a experiment 2D in a channel) "4* 1.5 * tx * (0.41-tx)/0.41^2" represents this profile:
I would need a equation for this kind of profile: That is for a curve of a boundary layer. Someone know how will be the equation for this curve to work with Elmer?
bitacovir is offline   Reply With Quote
Old   August 15, 2012, 08:17
Rami Ben-Zvi
Rami is on a distinguished road
Hi Bitacovir,
I have no access to Elmer manuals at the moment, so forgive me if the syntax is not exact.
Suppose - for example - that your axial velocity, U, is parabolic in the transverse coordinate, y, with
U = 1*y^2 + 2*y + 3
then use
$A = 1.
$B = 2.
$C = 3.
Velocity 1 = Variable Coordinate 2; Real MATC " $A * tx^2 + $B * tx + $C"
Sorry if I omitted a dollar or two...
Rami
Rami is offline   Reply With Quote
Old   August 16, 2012, 05:51
Originally Posted by Rami View Post
Hi Bitacovir,
U = 1*y^2 + 2*y + 3
then use
$A = 1.
$B = 2.
$C = 3.
Rami
Dear Rami:
Thanks a lot. I going to try this suggestion. Currently I was using http://www.comflow.nl/ that is easier to set up Inlet conditions such as profile of wind.
Here one example that I was doing...
Kind Regards.
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 16:35
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Macro fan modeling considering cross wind effect microfin FLUENT 0 January 1, 2012 03:07
PLS,how to set BCs for a fan model??? MANU FLUENT 1 April 9, 2006 07:05
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
