December 17, 2005, 09:01 |
An important Question
Hi everybody, I use a Full Multigrid algorithm and I wonder something.
With Neumann boundary condition, we know that the restriction of point near the boundary is special but what about the Neumann Operator: ( u(1)-u(-1)/dx ) = f where f is the neumann condition imposed). Is it important to restrict this Neumann operator, or should I use 'f' ( the same neumann condition ) on the coarser grid ??? Hope this is clear... Thanks for your response... Davoche |
December 29, 2005, 02:45 |
Re: An important Question
I am not sure to understand right. Normally I would apply exactly the same neumann bc to the coarser meshes. I would strongly recommand this. But you have to take care when one face has more than 1 neighbour face (local refinements). In this case you have to modify the bc's for the refined cells, because multigrid solves on each coarser mesh with the accuracy of the top level fine mesh, which depends strongly to the cell size. As a result you would see clearly the refinement borders in you contour plots. So, when you have refinements at the boundary area, I would suggest to mesh this area with face to face cells (means no local refinements). But of course it is possible to overcome this problem, but is not easy to discribe. I don't know if this was your problem. Best regards Hubert Janocha |
question about uds | tanven | FLUENT | 2 | July 5, 2015 11:22 |
General Question: Inlet- Outlet Mesh - have to be simular? | thisisit | FLUENT | 8 | July 11, 2011 11:26 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
