SITVC calculation
I am doing calculation on Secondary Injection Thrust Vector Control (SITVC) using Pressure inlet at the primary nozzle. Later I have to use mass flow rate instead of pressure inlet. In the calculation , I am using secondary injection port having different pressure inlet condition on that Port. My question is how I can use the mass flow rate in the primary nozzle and how I can use pressure inlet in secondary port in the Fluent calculation. Although I can do the calculation using the pressure inlet in the primary nozzle. Thanks in advance. |
