Negative lift in Modeling an airfoil design for wind turbine |
July 23, 2012, 13:05 |
Ram N Bishnoi
I am trying to model a airfoil design for wind turbine in fluent. Chord length of airfoil is 0.3m and angle of attack is 8deg. But I am getting negative value of lift coefficient. I already checked boundary conditions and all. Please suggest. |
July 25, 2012, 02:25 |
Ram N Bishnoi
Thanks Mr. Dargahi,
The problem consists rotation of 2D airfoil from 0 to 180 degree, means changing angle of attack. I am using wind velocity 5m/s and considered inviscid viscous model. In setting...I have confusion that during changing angle of attack should I have to change velocity component in boundary condition? and what about the reference values? In meshing also I have a slight confusion as I am using unstructured triangular grid with enough nodes to model turbulence. Please suggest. |
July 27, 2012, 08:35 |
duri
August 8, 2012, 22:39 |
#4 | |
Jos
With respect to the angle of attack, i guess you could obtain the cosine and sine values accordingly in the boundary condition for velocity input and the reference value(i.e. area) for a 2D case would be 1 ( i.e.chord length) but if for a 3D case then we would need to take into consideration the extruded length of airfoil in the third direction....Hope this helps... Last edited by joseph@CFD; August 8, 2012 at 22:54. |
Airfoil negative drag coefficent | James Forrest | Main CFD Forum | 9 | September 5, 2022 10:30 |
Lift force modeling in bubbleFoam | holger_marschall | OpenFOAM Running, Solving & CFD | 2 | December 10, 2007 15:24 |
Negative propulsive efficiency of a moving airfoil | zonexo | Main CFD Forum | 4 | March 7, 2007 00:16 |
Airfoil Lift and Drag | Dr. Laith K. Abbas | Main CFD Forum | 8 | July 2, 2005 03:32 |
steam turbine design | sameer mohrir | Main CFD Forum | 4 | September 24, 2000 23:29 |
