July 25, 2012, 04:49 |
Ground temperature
hayder
Rep Power: 14 |
Hi
I just wonder how to model the ground temperature, when using conjugate heat transfer method in CFD programs to make simulation for the thermal processes (energy simulation) in building. In other words if I use CFD program to make thermal simulation for the building (with CFD simulation) ,how to set the thermal boundary condition at the ground. With regards |
July 25, 2012, 07:14 |
Richard Parker
Rep Power: 13 |
Naturally, it depends in the CFD package you use. In Fluent, for example, you can enable the Energy equations and then add Temperature or Heat Flux in the Wall Boundary condition. It should be straightforward! Josep |
July 25, 2012, 09:17 |
hayder
Rep Power: 14 |
Dear Josep ,thank you for your prompt reply ,I know about the energy equation but I ask about the ground (in touch with earth mass) which can`t deal with it as normal wall ?
July 25, 2012, 10:32 |
Alex
Rep Power: 46 |
Assuming that the heat storage capacity of the earth is quite huge, you could go wit a fixed temperature boundary condition.
If this is not accurate enough, your computational domain could encompass the ground to a certain depth. |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
