Higher order formulation question
Old   July 27, 2012, 09:13
Default Higher order formulation question
peterciaran is on a distinguished road
Hi all
This is my first post on here and I'm starting by asking for help
I'm trying to build a simple code that will solve the advection equation. Starting from a simple upwind scheme then to a central differencing scheme then on to a third order scheme.
The first two schemes as you'd expect worked easily however once I've tried to move to third order I cant get any results.
so by using a finite volume formulation and polynomial fitting I get a formulation ranging from node E to W-3.
So my 1D formulation becomes;
AE(phi,i+1)+(1-AP)(Phi,i)-AW(phi,i-1)-AW1(phi,i-2)-AW2(phi,i-2)-AW3(phi,i-3)=D
So when i solve this in matrix form the result does not travel in the x direction at all but instead just reduces the values more and more.
an anyone help me?
peterciaran is offline   Reply With Quote
Old   July 27, 2012, 13:47
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by peterciaran View Post
Hi all
an anyone help me?
You should address more issue about your scheme...as I assume you are working on the equation d/dt phi + u d/dx phi = 0 (u = constant) please use notation "i" for the space-location and "n" for time-location
FMDenaro is offline   Reply With Quote
Higher order spacial derivatives chegdan OpenFOAM 0 February 9, 2011 12:54
Higher order Gradient Calculation CFDtoy Main CFD Forum 3 February 13, 2009 04:42
Higher order terms in the equations Argyle Main CFD Forum 7 October 31, 2008 07:41
eigen value analysis for higher order schemes Shyam Main CFD Forum 0 June 9, 2008 22:20
Higher order DG method for compressible flows jinwon park Main CFD Forum 0 May 16, 2008 12:10
