Help! How to hold turbulence in a 2d channel flow RANS simulation |
July 27, 2012, 11:58 |
dw
Rep Power: 13 |
Newbie here.
I am doing a 2D rans simulation to investigate some turbulence models. I am wondering how to make the flow turbulent? For example in a simple Re_tau=180 channel flow, or a little bit more than that. Pressure gradient driven, using some low Re turbulence model, and keep the mesh having y+<1. Then I set the initial nut=100*nu, k/e>100*delta_t, mass is kept constant on the solver's side (I am using an unsteady solver (URANS)). But I found the flow is always laminar or laminarized. This is very annoying. But I read so many papers, they all have a perfect velocity profile, How did they do that? Any secrets? Or what did I do wrong? Any ideas? -------- 1/153 |
July 27, 2012, 14:44 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
July 27, 2012, 14:57 |
dw
Rep Power: 13 |
Thanks for helping. Yes the velocity profile is here: [shared just for 24 hours]
http://f.imgtmp.com/Dcdfq.jpg |
July 27, 2012, 15:59 |
dw
Rep Power: 13 |
Is that because 2D cant sustain the turbulence structures, so to damp out all the turbulence? Or is that I should use RANS not URANS?
July 27, 2012, 16:09 |
#6 | |
Rep Power: 71 |
No ... you are solving a 2D statistically steady solution, you never see in RANS any other variable that zero-order statistics.... But your problem is that you are solving a smaller Re number, your profile arrives at y+ about 10 at the half-heigh! |
July 27, 2012, 16:16 |
dw
Rep Power: 13 |
I will test with other LRN models to see if my new implemented model is wrong somewhere. But have you ever use steady RANS to get a correct profile before? Which turb model did you use? Thanks
July 27, 2012, 16:39 |
Rep Power: 71 |
RANS is perfect in turbulent channel flow, you have some wrong in your setting/input
Display Modes | |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 17:26 |
Heated vertical channel flow RANS | ep4 | OpenFOAM Running, Solving & CFD | 0 | November 24, 2008 10:37 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 18:15 |
LES turbulence decaying in channel flow | cfdIsMad | CFX | 4 | July 4, 2008 07:29 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 18:23 |
