CFD analysis of Gas turbine blades
Like Tree3Likes
  • 1 Post By wasim raza
  • 1 Post By Manigandan
Old   July 28, 2012, 08:54
Default CFD analysis of Gas turbine blades
wasim raza is on a distinguished road
Hi friends,hope you are all fine....i am a new member here...i am about to start my final year project(named CFD analysis of gas turbine blades)of mechanical engineering..Regarding this i want to get help of you people that how should i take start..means from very beginning as i dont know much about CFD but its my passion to work on it...
Thank you
saleh alsubari likes this.
wasim raza is offline   Reply With Quote
Old   August 8, 2012, 11:15
saleh
saleh alsubari is on a distinguished road
i really need it too....hope i got help here
saleh alsubari is offline   Reply With Quote
Old   August 9, 2012, 04:13
Default Gas Turbine Blades
R. Manigandan
Manigandan is on a distinguished road
Hi wasim raza, may i know scope of your projects then only can to help you..
Manigandan is offline   Reply With Quote
Old   August 9, 2012, 04:15
R. Manigandan
hi saleh alsubari, May i know your project details?
Old   August 9, 2012, 07:57
Question
saleh
thanx alot for replying
my project is
i have given a turbine blades with mass flow rate as in input ,and i need to use star-ccm+ to find out rpm and torque associated with it , ..i tried to simulate it but i keep getting zero rpm....
i started by inserting my geometry ..after the mesh i did the physical properties
as steady ,moving reference frame and so on but i this case they need rpm as input ,where i need it as output,
pleas help
Thread Tools
Trackbacks are On
CFD in turbine Den Main CFD Forum 10 May 7, 2012 01:25
Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 pedrin84 ANSYS Meshing & Geometry 0 August 25, 2010 12:19
CFD analysis of turbine blades jayaero FLUENT 1 June 10, 2009 00:26
CFD analysis of turbine blades jayaero Main CFD Forum 0 May 30, 2009 06:17
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
