Most Efficient Numerical Method for Solving Boundary Layer Flows
Old   August 1, 2012, 09:42
Thumbs up Most Efficient Numerical Method for Solving Boundary Layer Flows
samina
samina is on a distinguished road
hi friends,
Can anyone tell me about some efficient n stable numerical schemes to solve Boundary Layer Flow Problem. thanks
With profound regards.
samina
samina is offline   Reply With Quote
Old   August 2, 2012, 07:06
leflix is on a distinguished road
Originally Posted by samina View Post
hi friends,
samina
Hi Samina
which kind of boundary layer problem?
If it is 2D and over a flat plate, solving Blasius equation is straightforward.
check this :http://moon.pr.erau.edu/~gallyt/ae30...ricBlasius.pdf
If the geometry is more complex than flat plate, use any good Navier-Stokes solver.
leflix is offline   Reply With Quote
Old   August 2, 2012, 12:48
Thumbs up
samina
thanks leflix,
you suggested a goood link.
My problem is not on an easy geometry, its the BVP for the flow over an expanding stretching cylinder, (in cylindrical coordinates) 3D geometry
Old   August 2, 2012, 13:14
Then the only outcome is to solve the full NS equations. Refine the grid near the wall. Hope the Reynolds number is not too high....
Old   August 4, 2012, 11:20
Post
samina
One more issue,I have NS eq of order four, while i have only three boundary conditions..
What should i do for the missing condition.
Regards
Old   August 4, 2012, 11:43
cfdnewbie
cfdnewbie is on a distinguished road
Regards
What kind of formulation of the NS equations do you have?? They are second order PDEs....
cfdnewbie is offline   Reply With Quote
Old   August 4, 2012, 12:00
Post
samina
Obviously, 2nd order PDEs (NS eqs for the viscous fluid).
but when i convert these equations to ODE, by using similarity transform for the stretching surfaces, order of the differential equation is raised by 1, so it becomes 3rd order ODE.
And when i solve the same problem for the 2nd grade fluid, i get ODE of order 4
Old   August 4, 2012, 13:16
cfdnewbie
Sorry, I don't know what a 2nd grade fluid is, but if you have 3 BCs from the similarity ( I assume what you are doing is similar to the classical blasius solution, which is a 3rd order PDE), then the last one has to come from this 2nd grade fluid, whatever that might be
Blasius boundary layer coupled with thermal boundary layer primary.destination Main CFD Forum 0 May 7, 2012 02:55
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
What's the numerical boundary layer Zhou Main CFD Forum 12 June 1, 2001 23:17
