-   -   C-grid and angle-of-attack for airfoil (http://www.cfd-online.com/Forums/main/105574-c-grid-angle-attack-airfoil.html)
cliftonperkins August 2, 2012 17:17
I want to simulate different angles-of-attack (AOA) for flow over the NACA 0012 airfoil. I'm using the NASA C-grids, from:
http://turbmodels.larc.nasa.gov/naca0012_grids.html
Re-meshing isn't an option and I'm not sure to handle the different AOA. There are results at the NASA website for different AOA, so I'm assuming there's a standard approach for dealing with this issue.
I know that the obvious thing to do is just change the inlet BC to match the AOA. But with this I run into a couple of issues for non-0 AOA:
- the flow is no longer parallel to the side (virtual) walls of the domain; I am using free-slip BC there, to help with convergence, but could try free inflow/outflow (aka Riemann BC I think) instead
- at one end of my inlet (inlet = C-shaped portion of boundary), I get "inflow" BCs that are actually pointing out of the domain (I guess I could modify the location at which "inlet" becomes "side" to avoid this, but would then need different region labeling for each AOA)
Does anyone have a recommendation on how to proceed?
I'm using a commercial CFD package, but probably better not say which one.
Thanks for all replies!!
cfdnewbie August 3, 2012 03:09
Hey Clifton,
just to clarify: are you doing sub or supersonic flows?
cheers
cfd newbie
cliftonperkins August 3, 2012 09:26
Thanks for your reply, cfd newbie. I'm sorry, I should have mentioned that it's incompressible flow and yes, subsonic.
harishameed33 August 14, 2012 02:23
hi
why dont you use pressure farfield boundary condition...
i have simulated the same 2D cases in fluent (commercial pakage) got good results even for aoa 10 deg and 15 deg
i dont know ur solver so cant comment on ur strategy
