Most Efficient Numerical Method for Solving Boundary Layer Flows |
August 1, 2012, 09:42 |
samina
Rep Power: 13 |
hi friends,
Can anyone tell me about some efficient n stable numerical schemes to solve Boundary Layer Flow Problem. thanks With profound regards. samina |
August 2, 2012, 07:06 |
#2 | |
Rep Power: 15 |
which kind of boundary layer problem? If it is 2D and over a flat plate, solving Blasius equation is straightforward. check this :http://moon.pr.erau.edu/~gallyt/ae30...ricBlasius.pdf If the geometry is more complex than flat plate, use any good Navier-Stokes solver. |
August 2, 2012, 12:48 |
samina
Rep Power: 13 |
thanks leflix,
you suggested a goood link. My problem is not on an easy geometry, its the BVP for the flow over an expanding stretching cylinder, (in cylindrical coordinates) 3D geometry |
August 2, 2012, 13:14 |
Rep Power: 15 |
Then the only outcome is to solve the full NS equations. Refine the grid near the wall. Hope the Reynolds number is not too high....
August 4, 2012, 11:20 |
samina
Rep Power: 13 |
One more issue,I have NS eq of order four, while i have only three boundary conditions..
What should i do for the missing condition. Regards |
August 4, 2012, 11:43 |
cfdnewbie
Rep Power: 20 |
August 4, 2012, 12:00 |
samina
Rep Power: 13 |
Obviously, 2nd order PDEs (NS eqs for the viscous fluid).
but when i convert these equations to ODE, by using similarity transform for the stretching surfaces, order of the differential equation is raised by 1, so it becomes 3rd order ODE. And when i solve the same problem for the 2nd grade fluid, i get ODE of order 4 |
August 4, 2012, 13:16 |
#8 | |
cfdnewbie
Rep Power: 20 |
Sorry, I don't know what a 2nd grade fluid is, but if you have 3 BCs from the similarity ( I assume what you are doing is similar to the classical blasius solution, which is a 3rd order PDE), then the last one has to come from this 2nd grade fluid, whatever that might be |
Blasius boundary layer coupled with thermal boundary layer | primary.destination | Main CFD Forum | 0 | May 7, 2012 02:55 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
Boundary Layer Question | scottneh | STAR-CCM+ | 3 | September 30, 2010 14:21 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
What's the numerical boundary layer | Zhou | Main CFD Forum | 12 | June 1, 2001 23:17 |
