Streamfunction-velocity derivation
Old   January 5, 2006, 21:34
Default Streamfunction-velocity derivation
Andrew Mettler Hayes
If I am trying to derive the streamfunction-velocity formulas do I start with the curl of the momentum equation and change that into the streamfunction-vorticity formulas and then back track the vorticities to streamfunctions? I am trying to convert the equations for flow through porous media as given by Jiang to streamfunction-veloctiy formulation. I have turned them into streamfunction-vorticity, but I want to get rid of the vorticities to help with boundary conditions.
thanks
Old   January 5, 2006, 23:13
Default Re: Streamfunction-velocity derivation
Adrin Gharakhani
But vorticity is actually generated at the boundary! So, it seems to me that one way or another you have to deal with vorticity... I'm not familiar with the porous media equation used in your case, but don't you end up essentially having a potential flow anyway (in which case there is no vorticity anywhere)?
Adrin Gharakhani
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
