Polynomial fitting
Like Tree1Likes
  • 1 Post By sbaffini
Old   August 9, 2012, 10:52
Default Polynomial fitting
Simbelmynė's Avatar
Simbelmynė is on a distinguished road
I am fitting polynomials of different degree to some data points.
p(x,y) = a + bx + cy
Question: If I fit the above polynomial to 3 points then I might get a singular matrix when I try to solve the system (e.g. if the points are located on the same axis). What is the rule here in order to Not get a singular matrix?
I wish to fit an arbitrary number of points to a polynomial of higher order and while the above case is simple to figure out I believe I lack the understanding to avoid singular matrices (some times it might work and other times it might not) when doing this.
Regards
Simbelmynė is offline   Reply With Quote
Old   August 9, 2012, 17:58
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enough
In 2D (x and y) and a polynomial whose maximum order is n the requirement is that no more than n+1 points are aligned. In 3D (x, y and z) you also have the requirement that no more than (n+1)*(n+2)/2 points can be on the same plane.
That's all i remember, but i guess there is some material around on the multi-dimensional polynomial interpolation.
As a side note, consider that for any valid point distribution you can always find a non valid one in the way of exchanging the position of just two points. Indeed, this operation has the effect of exchanging two rows in the interpolation matrix hence, as this imply a change in the sign of the determinant, somewhere along the path the determinant has become 0.
Simbelmynė likes this.
sbaffini is offline   Reply With Quote
Old   August 10, 2012, 03:33
Simbelmynė's Avatar
Thank you, this was helpful!
By alignment, I assume that you also include diagonal alignment, right?
Old   August 10, 2012, 05:35
sbaffini's Avatar
Paolo Lampitella
Yes, alignment in any direction (2D of course).
Old   August 10, 2012, 11:41
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
if you use Lagrangian simplex (triangles in 2D, tethraedron in 3D), you will be sure that the matrix is never singula
FMDenaro is offline   Reply With Quote
Thread Tools
Trackbacks are On
Polynomial thermophysical properties and laminar porous Zone vemps OpenFOAM 0 June 30, 2011 10:13
Polynomial thermophysical properties and laminar porous Zone vemps OpenFOAM 0 June 28, 2011 10:22
polynomial thermophysical properties jason.ryon OpenFOAM 2 May 11, 2011 06:16
Scalar polynomial for specific heat is not defined! navid STAR-CD 2 April 19, 2010 05:00
Shock Fitting Craig FLUENT 1 April 24, 2008 17:06
