Question for COSMOS FLOWORKS Tutorial Charpter 2
Old   January 8, 2006, 09:54
Default Question for COSMOS FLOWORKS Tutorial Charpter 2
OPticdesigner
Dear Madam or Sir I studied FLoworks (EFD.Lab) tutroial Chapter2 and found one question. How do they specify the Angular Velocity as 100 rad/s for representing swirling factor? I ccheck the parameter for PAPST DC-Axial, Series 400, 405 item. Its RPM is 6000 rpm. Can you show me how to get the Angular Velocity as 100 rad/s?
Steve Li
Old   January 8, 2006, 15:30
Default Re: Question for COSMOS FLOWORKS Tutorial Charpter
Jim_Park
Strange.
6000 revs/min is 100 revs/sec.
2*pi radians/rev makes 100 revs/sec is about 628.3 rad/sec.
Perhaps there's a misprint. Or (unlikely) you've misread the units.
Let us know what you learn.
Old   January 8, 2006, 22:27
OPticdesigner
HI,Jim Thanks for your instroduction. I tried to use Floworks to model the EBMPAPST DC-AXIAL Fan Series 400, 405 item. It is alos showed on the Floworks Tutorial Chapter 2.
1. Select the 405 item under the Fan Curves, EFD.Pro Defined, PAPST, DC-Axial, Series 400, 405 item. 2. Expand the Flow parameters item and select Swirl in the Flow vectors direction list. 3. Specify the Angular velocity as 100 rad/s and accept the zero Radial velocity value.
The descriptions listed above are on the tutorial.
I do not understand how he get the 100 rad/s to represent the DC-Axial Fan.
The rpm for EBMPAPST DC-AXIAL Fan Series 400, 405 item is 6000.
A question about horizontal film boiling tutorial? Asghari FLUENT 3 September 23, 2016 13:18
[OpenFOAM] Question about the kivaTest tutorial johan ParaView 1 October 27, 2008 07:07
A question on the first tutorial example bcavityb athlonshi OpenFOAM Running, Solving & CFD 7 October 23, 2008 11:28
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
natural convection tutorial question Cynthia Campbell FLUENT 2 June 29, 2001 19:09
