about under relaxation factor
Old   August 13, 2012, 04:56
Default about under relaxation factor
B Aram
landa is on a distinguished road
I have a question about setting under relaxation factor.
is changing the relaxation factor supposed to change the final answer?!
when i changed it in a problem, the final solution that i was expected wasn't gained and when i decreased it again, the final solution changed again
landa is offline   Reply With Quote
Old   August 13, 2012, 06:25
flotus1's Avatar
Alex
flotus1 will become famous soon enoughflotus1 will become famous soon enough
If your "final" solution is obtained based on a residuum, not on a number of iterations, then the results should be independent of the underrelaxation factor.
flotus1 is offline   Reply With Quote
Old   August 13, 2012, 09:02
Jonas T. Holdeman, Jr.
Jonas Holdeman is on a distinguished road
Yes it should, but this is not always the case. When the sequence of residuals is not monotonicly decreasing, it may not converge without relaxation. What is happening with relaxed convergence is that the advection velocity, i.e. Ubar in the expression (Ubar dot grad U), is implicitly filtered or smoothed, averaged over many iterrations. So what you get is not necessarily the solution to the original NS equation (which may not exist), but is the solution to a smoothed advection-diffusion equation. This will be the same as the solution to the unrelaxed equation where the latter exists (Ubar=U), but can provide a generalized solution when it doesn't.
Jonas Holdeman is offline   Reply With Quote
Old   August 13, 2012, 11:51
leflix is on a distinguished road
If the choice of your relaxation factor change your solution, so there is a bugg in your code.
With an improper value of relaxation factor your solution can blow up. with a good one the solution will converge. But there are plenty values for which the solution will converge. For all theses values the solution should be the same (especially for steady cases) and the only difference will be the rate of convergence.
As an example it is often recommended to underlax the pressure for incompressible flow. Underlaxation factor over 0.7 may blow up your code,it is really problem dependent. For UF =0.6 it may converge, but for UF=0.5 also and for UF=0.2 too. For all theses values between 0.2 and 0.6 you will obtain the same solution. But there is an optimal value for which your code will converge faster. Generally it is the highest value for which the code still converge just over this limit it diverges.
Some authors have prescribed that UF_velocity+ UF_p = 1
leflix is offline   Reply With Quote
Old   August 14, 2012, 03:14
B Aram
thanks for your considerations
my problem is a simple steady state problem that is devised just for evaluating the effect of under relaxation factor on convergance. the physics of problem indicates that the solutuion should be a linear gradient for temperature. it is true for URF = 1 but when the URF is decreased, it's no longer linear. although decreasing the factor has a positive effect on convergance.
Old   August 14, 2012, 04:24
So I'm afraid there is a bugg in your program in the way you implemented the URF.
Old   August 14, 2012, 04:33
B Aram
ok thanks alot
Thread Tools
Trackbacks are On
Under relaxation factor for external coupling dhxlxz CFX 10 August 11, 2015 20:52
under relaxation factor and the steady state jing113cn FLUENT 0 November 2, 2009 13:13
Relaxation factor Benzaa Main CFD Forum 1 August 18, 2009 07:27
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 15:37
Relaxation factor Moon CD-adapco 1 June 13, 2003 11:13
