September 10, 2012, 06:44 |
2nd order schemes only 1st order accurate?
Rep Power: 13 |
Hi all,
I am running a volume of fluid simulation with highly turbulent (k-epsilon model) water flowing in a 2D domain. I am using the Non-iterative time advancement option with a fractional step. I have set all discretisation schemes to second order (Momentum, Turbulent Kinetic energy and transient formulation) using PRESTO! for pressure and Modified HRIC for VF. When I check for grid convergence I only get first order convergence. I am unable to check for finer meshes due to computation time. I understand there is inaccuracies associated with both the VOF method and k-epsilon model however there still should be 2nd order convergence.. right?? Any recommendations? I am about to progress and just talk about how 2nd order accuracy could not be obtained due to the complexities of the flow.. is that bad practice? Thanks for any advice!!! |
September 11, 2012, 04:10 |
ata kamyabi
Rep Power: 17 |
Hi
Did you have an orthogonal mesh? I think orthogonality can reduce the order of accuracy. Or may be your mesh is not so fine. |
September 11, 2012, 05:22 |
#3 | |
Rep Power: 13 |
Yes I am using a orthogonal mesh. What mesh should I be using? Unfortunately due to time constraints and lack of resources I am unable to reduce my mesh size any further. It could potentially be the issue, but I feel my mesh is fine enough. |
September 11, 2012, 06:16 |
ata kamyabi
Rep Power: 17 |
And what is the maximum aspect ratio in your mesh?
Display Modes | |
Which is better for CFD 4 core i7-2600 or AMD 8 core FX-8150? | GregShaffer | Hardware | 3 | May 7, 2015 14:26 |
IS calc. with 2nd order discret. always necessary? | Azman | FLUENT | 2 | March 14, 2013 05:28 |
Solution scheme: 1st, 2nd order, etc in momentum eqs | nottern | Main CFD Forum | 1 | May 11, 2012 01:30 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 08:12 |
2nd order interpolation for NS solver | Quarkz | Main CFD Forum | 6 | July 15, 2005 22:50 |
