modelling a free surface with the FVM
Old   February 1, 2006, 10:51
Default modelling a free surface with the FVM
Philip Simons
I intend to model a free surface that will undergo only small displacements with the colocated body-fitted FVM in 3D. I intend not to use the VOF or level-set method but move the grid (untill convergence). The flow bc on the free surface can probably be just p=0. Non-tangential velocity components will arise on mid-face points on the free surface. To displace the grid I need the nodal (=vertex) velocities (or displacements..), but that is not where I have my velocity field. The problem has been described in Peric-Ferzinger. All for the steady case (looking for the steady surface position), nothing transient. Does someone know any recent developments in this? thanks, Philip
Old   February 1, 2006, 13:26
Default Re: modelling a free surface with the FVM
Ruben Paredes
Hi Philip
I am not an expert, but I worked with a similar case during my Bachelor Thesis. I implemented one method described by Takanori Hino (1997) and he used the laplacian-weighted averaging method(presented by Rausch R. D."Spatial adaptation of unstructured meshes for unsteady aerodynamic flow computations" 1992, AIAA),in order to compute the variables at the node.
Good luck, ruben
CFX convergence issues with free surface adenlan CFX 3 September 2, 2011 06:43
free surface modelling shubham mishra FLUENT 2 September 26, 2008 06:13
BC for free surface pilar FLUENT 3 January 14, 2004 07:36
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
