Flow in a Pipe having protrusion inside it
Old   January 25, 2006, 06:22
Default Flow in a Pipe having protrusion inside it
Hari Analakkat
plz help me regarding the flow & heat transfer modelling for a pipe having a protrusion inside it.
pipe is cylindrical and the protrusion is a cylindrical piece(sensor is mounted on the pipe).Assume the flow is laminar.which all terms can I neglect in the general Navier-Stokes equation for cylindrical coordinate.?
also plz give me the procedure for getting wall heat transfer coefficient once the flow is solved.
if not posssible to reduce the terms , plz suggest me best and easier FDM scheme for solving this 3-D flow model
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 11:33
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 10:38
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
flow in pipe with momentum and energy source Atit Koonsrisuk CFX 3 March 29, 2005 16:58
