phase field or Cahn-Hilliard method
Like Tree1Likes
  • 1 Post By Junseok Kim
Old   January 30, 2006, 06:11
Default phase field or Cahn-Hilliard method
dusky.he
Is anyone familar with the method of phase field or Cahn-Hilliard? Could you tell me what is Mobility and and how to find the number for specific fluid, such like water. I read two paper, one set 1, another is quite small.
In addition, I can not understand why the Helmoltz free energy can be difined as F(c)=c**2(c-1)**2, here c is the concentration
Thanks a lot
He
Old   January 30, 2006, 17:38
Default Re: phase field or Cahn-Hilliard method
Pete
Could you specify what kind of problem you want to solve? phase separation or just interfacial flow between two immiscible fluids?
Pete
Old   January 30, 2006, 18:51
Dusky.He
I want to simulate the liquid-vapor two-phase flow. The problem is how to solve the sigularity of contact line. I adopted the Navier slip boundary, but it seems unsuited for my case for there was significant bulk velocity and the slip velocity was not matched to the bulk velocity. So I want to use phase-field method, it is reported that it can simulate the contact line movement naturally.
I read the papers by Prof.Jamet and Dr Kim. I can understand some of them, but I do not know how to relate the parameters, such like Mobility, Free energy etc., to the real working fluid, say water and gas.
Old   February 2, 2006, 16:43
Junseok Kim
You may consider the phase-field method as a computational tool, then Mobility works for the relaxation of the interface profile just like reinitialization of level set in level-set method. Free energy forces two phase separated.
So, the bottom line is, we want Mobility as small as possible.
cgisl likes this.
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
2D Field Panel Method Source Code Shukla Main CFD Forum 3 January 20, 2011 12:51
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 03:47
Differences between VOF and phase field 2L Main CFD Forum 2 July 4, 2004 13:30
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method Qing Hao Main CFD Forum 2 January 8, 1999 23:31
