The boundary layer thickness on an airfoil
Like Tree2Likes
  • 2 Post By truffaldino
Old   September 13, 2012, 02:18
Default The boundary layer thickness on an airfoil
Nick
Nick R is on a distinguished road
Hey guys,
I know that on a flat plate the boundary layer thickness is the thickness where streamwise velocity reaches 99% of the freestream speed. How does this work on an airfoil since the flow speeds up above the foil and slows down beneath it? Do we still use 99% of the free-stream as the thickness ?
cheers,
Nick R
Nick R is offline   Reply With Quote
Old   September 13, 2012, 09:37
MHP
mhp
MHP is on a distinguished road
Originally Posted by Nick R View Post
Hey guys,
cheers,
Nick R
Yes,of course.
No matter how much is your speed, whenever your speed in the perpendicular direction relative to the surface reaches 99% of the free stream,you can calculate BL thickness at that point.
MHP is offline   Reply With Quote
Old   September 13, 2012, 09:56
truffaldino's Avatar
truffaldino is on a distinguished road
Hey guys,
cheers,
Nick R
Even on a flat plate one uses different notions of thikness for different purpoces. More meaningful (than 99%) notions of thikness are displacement thikness and momentum thikness. This depends on what for you need this thikness. If one wants to join inviscid solution far from airfoil with viscous bl solution it is necessary modify airfoil profile by displacement thikness. If one wants to find drag force, then it is defined by momentum thikness.
truffaldino is offline   Reply With Quote
Old   September 13, 2012, 20:22
Nick
thanks it makes sense
Old   September 14, 2012, 03:50
Post
MHP
mhp
Originally Posted by MHP View Post
Yes,of course.
As an additional note,please pay attention that in advanced BL references the pressure gradient over the geometry is another issue that enter in BL thickness calculations, we use 0.99% of free stream velocity for flat plate,because in that case the free velocity is constant over the plate and there is no pressure gradient, but for airfoil depending on the geometry profiles there is pressure gradients.
good luck.
Old   October 23, 2013, 10:25
Default A nagging thought on thickness notions
Daniel
fadiga is on a distinguished road
I have to say, this "..there are more meaningful notions of thicknss.." talk is rather annoying. I have seen countless posts, also on other forums where this is stated!
IMO - Whichever notion you decide to go for, you need to define some sort of cut-off between your inner and outer flow, since even for the displacement and momentum thicknesses, you have to decide how much wall effects to incorporate...
fadiga is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
Wall coordinates and boundary layer thickness bentmol Main CFD Forum 1 July 3, 2011 20:44
How to know the know the Boundary Layer thickness and the edge velocity on a 3D wing? mohammad Main CFD Forum 8 May 16, 2011 12:21
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 07:23
