SSIIM 2, vertical elevation of the water surface, transient water flow parameters
Like Tree1Likes
  • 1 Post By qinjie1629
Old   September 19, 2012, 09:22
Default SSIIM 2, vertical elevation of the water surface, transient water flow parameters
Miss Mummputz
Mummputz is on a distinguished road
I want to simulate a step- pool ramp with ssiim2. However, the measured vertical elevations of the water surface don't match with the simulated ones- while the measured heights increase lightly where the stone bars are, there is no influence at all of the stone bars on the water heights in the simulation and the water surface is totally smooth. I increased the stone bars and their roughness, but this doens't help.
This is why I wanted to introduce transient water flow parameters by using the F 33 data set and a gravity- algorithm by using the F36 15 data set. However- this doesn't work and the solution never converges!!! I'm very much beginner with all of that and it would be very useful to have an example where these data sets do work. On the norvegian ssiim- homepage, there is such an example, but it doesn't work with the currently downloadable ssiim2-version. If anybody could provide me an example- I would be so glad- thank you!!
Mummputz is offline   Reply With Quote
Old   October 22, 2012, 00:35
Jie Qin
qinjie1629 is on a distinguished road
Maybe you can post your control and unstruc file, I can run it to find out what is the problem.
Mummputz likes this.
qinjie1629 is offline   Reply With Quote
Old   October 23, 2012, 08:09
Default control and unstruc file
Miss Mummputz
thank u, so nice!!- attached the control and unstruc files
all the best!
Old   October 23, 2012, 11:39
Jie Qin
I think the most possible reason is attributed to the mesh quality. When you open the SSIIM2, choose 'View' ->'Profile I', you can find that the mesh is too thick in vertical direction and too sparse in longtitudinal direction. Generally, individual grids should close to 'square' not 'rectangular' shown in your mesh. You can try to rebuilt the mesh and run it again.
Old   October 24, 2012, 02:54
Miss Mummputz
I've already tried that before- it didn't work, that's why I tried to create a mesh as simple as possible
I can't attach the unstruc file, bcse it's too big, that's why I send u the control and koordina file
File Type: zip control.zip (360 Bytes, 20 views)
Old   October 24, 2012, 09:05
Jie Qin
I tried to run the case you post for the first time by simply modifying several parameters and the resutl is attached. The deformation of water surface around the triangle can be observed. The flow discharge is 4. You can change the discharge from 1 to 5 to see the variation of flow surface. I am not sure whether this is what your expected result.
I found the Koordina file doese not like a really topography of step-pool, so did the fisrt unstruc file. So, how did you specified the flow discharge and flow depth in the control file. Different flow discharge and flow depth will affect the flow depth near the obstacle significantly.
Old   November 18, 2012, 13:39
Default geodata
mona
mona nemati is on a distinguished road
i have many problem with geodata file in ssiim2,when i involve a geodata file in path ssiim2,for see the points cliking "view> GridEditor> Geodata point"
but any point i can't see,until click the legend,then i see cell number in ssiim,but i dont know how make grid with geodatapoint,is there anyone help me here?
mona nemati is offline   Reply With Quote
Gravity Flow Velocity Computation Jerry McHugh Main CFD Forum 1 March 16, 2007 13:24
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
