What is the total energy for incompressible fluid?
Old   January 20, 2006, 02:47
Default What is the total energy for incompressible fluid?
Harry Dong
For compressible fluid, the total energy of per unit mass of fluid is
H=CpT+1/2*V^2
From this equation, we can write other variations. There should be no any question for that.
I write in a manuscript:
For incompressible fluid, the total energy of per unit volume of fluid is
p+1/2*rho*V^2+rho*g*z ...................... (1)
This is from the text book of fluid mechanics.
Bernoulli equation means that the quantity expressed by Equation (1) is constant along a streamline in inviscid fluid.
We can refer to:
http://www.centennialofflight.gov/es...vation/TH8.htm
However, The Reviewer of the Journal writes: "This is a Bernoulli construct but is not energy as far as I can tell."
Another Reviewer commented the same: "This is the Bernoulli head, but not the energy."
Can anybody comment for this?
Old   January 20, 2006, 06:14
Default Re: What is the total energy for incompressible fl
andy
Without more context it is not possible to answer this question.
The problem is that one would need to know what you want "total energy" to represent for your incompressible fluid. The assumption of incompressibility makes the fluid's thermodynamic state inconsistent. Nonetheless one can often sort out mechanical quantities without too much problem.
Old   January 20, 2006, 07:26
Harry Dong
I mean the total mechanical energy of per unit volume fluid in incompressible flow.
Old   January 20, 2006, 09:04
andy
This is a different quantity. A widely held book which derives and compares transport equations for this quantity and energy is "Transport Phenomena" by Bird, Steward and Lightfoot. Depending on context, you might still need to be careful about quantities with a thermodynamic meaning for your incompressible fluid but so long as whatever you are trying to argue is mechanical you probably will be able to make a case your reviewers are happy with. Again, without context it is difficult to know.
Old   January 20, 2006, 22:47
versi
The standard definition of total energy is: internal energy + kinetic energy . your H=CpT+1/2*V^2 is actually total enthalpy/mass = CvT+ 1/2*V^2 + P/rho, it is not total energy. For steady inviscid flow, the total enthalpy/volume is constant along a streamline. This is equivalent to Bernoulli equation: p+1/2*rho*V^2+rho*g*z for incompressible flow with gravity into account.
Old   January 20, 2006, 22:48
Harry Dong
I have given the context in my first post. Is it not appropriate?
It is:
For compressible flow, the total energy is
H=CpT+1/2*rho*V^2
My purpose is to express the counterpart for this term in incompressible flow.
Thanks.
Harry
Old   January 20, 2006, 23:44
Kasyap
hi....
the equation u have written comes from the integration of elemental momentum eqn dp/rho+v dv+g dz=0 with the assumption of incompressibility.for a compressible fluid pressure is not just a mechanical parameter but is a state varible.So integrate the above eqn with the help of eqn of state
regards
kasyap
Old   January 21, 2006, 01:12
worasit
Your expression is total mechanical energy derived from the momentum equation for incompressible flow.
Did the total energy you mean include the thermal energy used in the energy equation?
However, there is a link between the momentum equation and the energy equation in deriving Bernoulli equation.
In my opinion, the total energy (include thermal energy) may be extracted to clerify the physical meanings of all terms in the governing equation. Only some applications require the formulation based on the total energy.
I may be wrong. Please discuss with other person.
Old   January 24, 2006, 06:52
andy
It does not explain the point you are trying to make from which one might be able to deduce what you are trying to equate in both compressible and incompressible flow (assuming this is what you are trying to do).
The problem with equating themodynamic properties in compressible flow with their "equivalent" in incompressible flow is that the general thermodynamic relations do not hold for the latter. Some reduced relations might depending on exactly what you are doing.
What can often work are arguments based on mechanical quantities like work so long as you do not push the meaning of pressure too hard.
Old   January 24, 2006, 17:07
Pete
I guess what the referee means is you should choose 1/2*rho*V^2 as energy. Because the flow is incompressible, pressure shouldn't appear in the energy. And also, the internal energy doesn't have a feedback on the momentum equation as it does in the comperssible case, thus internal energy is always not considered in the incompressible flow.
Just my opinion.
Pete
Old   January 25, 2006, 03:43
  #11
Harry Dong
Thanks. but
For steady VISCOUS flow, the total enthalpy/volume is constant along a streamline too.
Old   January 25, 2006, 04:47
  #12
andy
This is a commonly held view but it is wrong. The viscous term in energy transport equations has two components: the first is the irreversible transfer to internal energy and the second is the reversible work done on the fluid element. If there is a gradient in the latter in the direction between streamlines there will be a transfer of energy between the streamlines.
Boundary layers provide good examples because the viscous forces are high and gradients in the shear stress will generally act to transfer energy between adjacent streamlines. Curving the boundary layer and/or working it against and adverse pressure gradient will induce nice gradients in the shear stress and make the effects apparent.
Old   February 4, 2006, 00:55
  #13
vm
What you write is total enthalpy not total energy. Total energy is
E=CvT+1/2*rho*V^2
If you want to express
H=CpT+1/2*rho*V^2
in incompressible flow use thermodynamic relation
TdS=dH-dp/rho
and set rho=const
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
how to analyze mechanical energy loss of fluid? Lcw FLUENT 3 October 27, 2004 11:22
total mass flux correction for compressible fluid? Francesco Di Maio Main CFD Forum 0 August 21, 2000 04:23
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
