Finite element method applied to external flows
Old   September 21, 2012, 07:14
Unhappy Finite element method applied to external flows
ssr
janya
ssr is on a distinguished road
Hi all
I am facing some difficulties while simulating external flows (flow past circular & square cylinders) using FEM.
The solution algorithm used is the Eulerian velocity correction approach.
The difficulty i am facing is that the lift and drag coefficient plots, with respect to time, experiences low amplitude and high frequency wiggles. It seems to be due to the pressure contribution to the aforesaid coefficients.
if anyone could give me some insight on how to diffuse this problem, it would be very helpful
Thanking you in advance
ssr
ssr is offline   Reply With Quote
drag coefficient, external flow, fem, lift coefficient
Is CFD coding in finite element method a formidable job? bearcat Main CFD Forum 0 June 18, 2010 20:53
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 19:24
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 14:40
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 18:28
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 02:34
