February 9, 2006, 11:37 |
Porous medium metal foam heat exchanger.
Am wondering if my approach with this is correct. Have modified thermal conductivity k and specific heat cp of my fluid based on volume fractions of metal foam and fluid. Also, seems like pressure drop will not affect thermal performance.
Heat exchange of metal foam is about twice that of conventional baffle-type design. Furthermore pressure drop can be greatly reduced, see above. Also would appreciate if anyone can provide information about permeability K and form coefficient C of aluminum metal foam since suppliers won't release much data. Thanks for any assistance. David Dunavant |
February 9, 2006, 14:45 |
Re: Porous medium metal foam heat exchanger.
if you have already done pressure drop readings you can calculate the K and C values. You need to take multiple pressure drop readings for various velocities, and then do a pressure drop reading across the open channel. Subtract the two to find what the pressure drop was due only to the porous media. Then, fit your data to a second order equation.
Then, knowing the constants for the variables you can solve for K and C. C is the inertia coefficient. dP=[(mu*L)/K]*Vd + [(rho*C*L)/K^.5]*Vd^2 where mu - kinematic viscosity L - length of porous section K - permeability Vd - darcian velocity rho - density C - inertia coefficient Jiang (and other authors) have equations for K and C pertaining to packed beds, but I found them to be different for foam. Burmeister gives an equation for K for porous media; K = (porosity*Ap)/(8*pi) where Ap = area of pore you can estimate that if you know the ligiment diamter and the pores-per-inch (PPI). Or, if you know the pore diameter. K = (porosity*Dp)/(32*pi) where Dp = pore diamter I am modeling this now, and I did not change my Cp value. I did modify the thermal conductivity of my fluid based on the temperature. Pressure drop changes all kinds of things; F, C, Re, Ux, and Vy, among other things - all of which play a part in the heat transfer |
February 10, 2006, 08:24 |
Interesting app. What about the issues of (dirt) fouling and subsequent increased blocking of the foam?
February 10, 2006, 10:30 |
Thats a very good practical question. Suggest looking into a pre-filter placed before the unit. Allow for the pressure-drop in your circuit hydraulics.
Des Aubery... |
February 13, 2006, 15:11 |
a pre-filter would increase the amount of air bypass for an open type system or decrease fan flow rate or both. Either way it drops the air flow through the foam. An interesting trade off to investigate!
February 13, 2006, 20:51 |
Without a pre-filter, the airflow will definitely drop off... as the foam becomes blocked. Then the problem becomes how to unblock the foam, which is not always too easy.
February 16, 2006, 10:13 |
I have also found that the thermal non equilibrium model is the model to use when modeling a porous media heat exchanger. Except at very low Re where the residence time of the fluid in the porous media is high and, therefore, can reach the same temperature of the porous material.
Display Modes | |
Lack of local thermal equilibrium in porous medium | Chander | CFX | 4 | March 4, 2012 05:07 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
heat exchanger problem(concentric tube+ porous media ) | shin26 | STAR-CD | 0 | May 14, 2011 09:37 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Heat Exchanger Simulation | tightaznbreaka | FLUENT | 0 | March 18, 2010 16:45 |
