Outflow boundary condition for convecction-difussion problem.
Old   September 27, 2012, 00:20
Default Outflow boundary condition for convecction-difussion problem.
juanelo14 is on a distinguished road
Hi everybody, first of all I apologize for my english, it's not my first language.
I´m making my own code in Matlab for solving a Two Energy Equation Model (Porous media NTE) but i have a doubt about how to implement an outflow boundary condition for the fluid phase.
I´m working one dimensional flow in a very simple geometry, a square, the flow is in the x-direction.
I´m using the control volume method (Finite volume).
I´m using the power law scheme.
Remembering the general form of the control volume formulation:
aP*Tp=aE*TE+aW*TW+aN*TN+aS*Ts+b
aP=aE+aW+aN+aS-Sp*DX*DY+(Fe-Fw)*DY
My confusion lies in what it's satated in th Suhas Patankar´s book:
suppose the outflow boundary is the east boundary, Patankar states tha i should set the aE coeficient of the adyacent node to zero in order to eliminate the influence of the boundary node, and then let the value of the temperature be extrapolated from the upstream values.
according to what is stated above, should i just turn the aE coefficient to zero, and eliminate it's influence on aP or keep it.? And what about the boundary nodes, should i use the same aproach or should i use an extrapolation function (second order backward difference maybe?) or just stay stuck with the general formulation.
On the other hand, if i analyze the physical interpretation (or mathemathical) of the outflow boundary condition, it reduces, to assume the normal gradients of the flow variables (including temperature) are zero. Should i make a new discretization for the boundary node considering the above statement ?
I hope somebody can help me, thanks!!!
juanelo14 is offline   Reply With Quote
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
problem with boundary condition??? smn CFX 5 November 24, 2009 06:37
convective boundary condition for outflow BC Pang Shengyong Main CFD Forum 1 August 24, 2007 17:21
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 12:49
