September 27, 2012, 08:30 |
can i use cfd using matlab
ashraf H
Dear all
can i use CFD Using MATLAB if answer is yes ? if u have examples ,books ,thesis i need to use CFD Using MATLAB for buildings (high rise building) help me please |
September 27, 2012, 10:49 |
Rep Power: 13 |
Yes you can. I don't know how much experience do you have in Matlab, but you can use fortran codes or C++ codes as a guide, and adapt it to MAtlab.
September 27, 2012, 11:05 |
Rep Power: 13 |
if you are new with this maybe this book can help you: "Applied Numerical Methods Using MATLAB" Won Y. Yang, Wenwu Cao,Tae-Sang Chung and John Morris.
September 27, 2012, 11:41 |
Francesco Capuano
Rep Power: 15 |
What do you think about the performances of Matlab with respect to Fortran or C/C++, for what concerns CFD-related codes? Does it work well in parallel?
I was wondering if a well-written Matlab code can be as fast as (or even faster than) consolidated languages such as Fortran or C. |
September 27, 2012, 12:57 |
#5 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Long and rant'ish answer: I just got give my two (or ten) cents here I've got plenty of experience coding with MATLAB, FORTRAN, C/C++ and I've even made C mex-files to speed up performance in performance-critical code that was running in MATLAB. Unless todays MATLAB has super-evolved (it's been 5 years since last time I did any high performance related coding in MATLAB), but the principle should remain the same today:
The end result is usually always the same:
And then there's always the power factor: if you have only a few of hours to develop the code from scratch, but have a super-computer near by, then by all means, use MATLAB assuming it's already installed and tested on said super-computer... Of course this also assumes you've got a lot of experience in coding said specific CFD code you're planning on using... because CFD is a mathematical world in it's own right... Have fun! Bruno
September 28, 2012, 04:13 |
Francesco Capuano
Rep Power: 15 |
Thank you Bruno, I guess I couldn't hope for a better answer
CFD in matlab | Dougal MCQueen | Main CFD Forum | 1 | December 5, 2003 06:45 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 04:48 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
