How can we observe shock in Mach Contour profile of a turbine?
Old   September 28, 2012, 11:22
Default How can we observe shock in Mach Contour profile of a turbine?
Arijit Hazra
arijith is on a distinguished road
How can we identify shock -both oblique and normal-from Mach contour profile? what are the identifiable features?Can anyone please expalin with any image....It would be great help...thanks in advance.
arijith is offline   Reply With Quote
Old   September 28, 2012, 18:31
agd
agd is on a distinguished road
What happens to the Mach number when a normal shock appears? A normal shock causes the flow to decelerate from M > 1 to M < 1 over a very small distance. So how would that look on a Mach contour plot? Across an oblique shock, the velocity component normal to the shock drops across a small distance, while the tangential velocity is unchanged. What would this look like if you plot the velocity vectors? The Mach number contours won't be as tightly clustered, but a look at the velocity vectors can clarify what you are seeing.
In general shocks will look like a tight clustering of Mach contours on a contour plot, but understanding the flow physics will help you understand why certain flow features look like they do in post-processing.
agd is offline   Reply With Quote
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Does anyone have 3D blade profile of wind turbine? kenya0514 Main CFD Forum 5 March 9, 2015 14:06
No shock in airfoil 0012 case despite of Mach number exceeds 1 schwermetall OpenFOAM 53 November 11, 2011 05:00
Mach Contour on water vapor compressible flow Tony FLUENT 4 July 15, 2010 11:20
non-dimensional analysis in Fluent Endee FLUENT 8 September 7, 2005 16:16
