What y+ value shall we choose for laminar flow?
Old   October 4, 2012, 07:48
Question What y+ value shall we choose for laminar flow?
lnk
lnk
lnk is on a distinguished road
May I ask what y+ value shall we choose for laminar flow? Is that the same as for turbulent flow? Could I still use the calculator given by this forum? (http://www.cfd-online.com/Tools/yplus.php)
Thank you very much.
lnk
lnk is offline   Reply With Quote
Old   January 26, 2013, 05:58
Question
Anna Tian's Avatar
Shoushou Tian
Anna Tian is on a distinguished road
Originally Posted by lnk View Post
lnk
I'm also wondering of this. Could anyone answer this question?
Best regards,
Shoushou
Anna Tian is offline   Reply With Quote
Old   January 27, 2013, 12:13
Default viscous-sub-layer
Raambi is on a distinguished road
The y+ value is important for the turbulent-model. It defines the height of the viscous-sub-layer where a laminar flow near the wall in turbulent flows occurs. I'm not a specialist but i would say it doesn't matter how big the height of your first cell is because there isn't a turbulence model.
regards
Raambi is offline   Reply With Quote
Old   January 27, 2013, 15:51
mohsen
mohsenz_136 is on a distinguished road
hi the y+ is only important for turbulent flow because it used in turbulent flow.
boundary layer is three region in turbulent flow they are sub layer , buffer layer & log layer. velocity is linear in sub layer and it's logarithmic for log layer.
if y+ was below 5 then the first cell is in sub layer. velocity for first cell obtain linearly if y+ was larger than 30 the the first cell is in log layer . velocity for first cell obtain logarithmic. however boundary layer of laminar flow is one region and it's velocity is defined we do'nt need y+ for laminar flow
mohsenz_136 is offline   Reply With Quote
Old   January 27, 2013, 17:24
Lucky Tran
LuckyTran is on a distinguished road
y+ is not typically mentioned in laminar flow but actually y+ can be defined for even laminar flows (actually it carries more physical meaning in laminar flows than turbulent ones).
lnk
That calculator uses skin friction correlations for turbulent flows and will not work for laminar flows. So it is best to avoid it. The grid requirements for laminar flows is not based on the need to achieve a particular Y+ value, but rather a sufficiently refined grid is needed to resolve all important flow features. Hence Y+ is not often not mentioned in laminar flows since you do not need to check for y+ < certain value in order to guarantee a specific wall approach is being used.
Old   January 28, 2013, 08:47
Filippo Maria Denaro
FMDenaro will become famous soon enough
Consider the example of the plane channel flow. Then,
y+ = u_tau *y/ni = (u_tau *H/ni) * (y/H) = Re_tau* y'
being y' the non-dimensional position along the vertical direction. Assuming that y'=1 in the half-heigh of the channel, as in laminar flow one assumes Re_tau=O(1), you see that y+ will be very very small close to wall and will be O(1) in the half-height.
FMDenaro is offline   Reply With Quote
Old   February 2, 2013, 08:24
Question
Anna Tian's Avatar
Shoushou Tian
Thanks for your answer. But in order to resolve laminar boundary layer well, we still need a lowest wall cell width criteria, right? For example, what wall cell width would you choose for laminar pipe flow?
Best regards,
Shoushou
Old   February 3, 2013, 05:29
venki
venkateshaero is on a distinguished road
calculate first cell height based on boundary condition
venkateshaero is offline   Reply With Quote
Old   February 6, 2013, 12:11
Question
Anna Tian's Avatar
Shoushou Tian
Could you briefly give a short example of how? Thank you very much.
Best regards,
Shoushou
Old   February 15, 2013, 10:17
Lefteris
Aeronautics El. K. is on a distinguished road
You can calculate the maximum displacement of the boundary layer from the Blasius solution and then you can figure out how many points you need in order to cover this (with a geometric distribution let's say) after you decide your initial ds. Usually, the initial ds should be small enough, let's say of order 10^-4.
Aeronautics El. K. is offline   Reply With Quote
Old   February 15, 2013, 16:27
Lucky Tran
Order of magnitude analysis will give you that y+ = 1 if you are at approximate 1/1000 of the overall boundary layer thickness.
I usually take 3 orders of magnitude less the boundary layer thickness and then take half that height if I want to be conservative.
El. K. suggested 10^-4 which should also work.
You just need to estimate the boundary layer thickness somehow (can always resort to Blasius solution).
Old   March 3, 2013, 18:54
Question
  #12
Anna Tian's Avatar
Shoushou Tian
Does that mean you are using even a smaller wall cell width than the 'Y+=1' wall cell width for laminar flow?
Best regards,
Shoushou
Old   March 4, 2013, 04:56
andy
andy_ is on a distinguished road
The modelling assumptions used with turbulence models usually require the first cell to be placed around a particular y+ location. For some it is deep within the laminar sublayer where the turbulent stresses are insignificant (y+ < 1) for others it is in the equilibrium layer (y+ ~ 30) where the assumption that turbulent energy production balances turbulent energy destruction and the transport terms are negligible.
Laminar flows have no turbulence models and hence have none of these constraints on y+ for the first cell. What is required for the first cell and every other cell in the grid is that the gradients in the flow are adequately resolved. This is a function of the discretisation scheme and how well the gradients need to be resolved at the cell location. For example, a fully developed flow in a pipe may require only 1 cell to be fully resolved with a higher order numerical scheme or tens of cells for a low order scheme.
A resolution criteria based on y+ is going to be rather limited in applicability compared to a normal one based on gradients of the solution variables.
andy_ is offline   Reply With Quote
Thread Tools
Trackbacks are On
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
Flow meter Design CD adapco Group Marketing CD-adapco 3 June 21, 2011 08:33
How to choose a good model for multiphasis flow ? Yasmail AKARIOUH FLUENT 2 April 21, 2008 02:12
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
